Results 1 to 4 of 4
Thread: HELP please / assistance: Carb - Fuel Pump - Valve Cover - Emissions Thermostat Valve
    Nor Cal
    1980 Plymouth Arrow Truck
    Hi Everyone,
    Trying to get my '80 Plymouth Arrow P-up w/ 2.0 ( G52B ) 4spd back on the road.
    Fuel Pump diaphragm is leaking, causing an oil leak.
    Went to my local auto supply and got a fuel pump. Turns out it does not fit.
    I went online and other auto supply stores in my area. They all list the wrong pump.
    Same goes for the valve cover. I did specify it's the 2.0, not 2.6.
    Any suggestions were I should look ? Does anyone want to sell me the parts?
    I am looking for the following items:
    - CA OEM CARB to manifold gasket. I had to remove carb to get to install what I thought was the correct new fuel pump.
    - 2.0 engine Valve Cover Gasket with accompanying grommets.
    - An emission related thermostat valve ( I have pics of the part )
    - A A/C Evaporator / Drier for the Air Conditioning unit. I hope to resurrect the dealer installed A/C unit.
    - Rear Window seal.
    - Clutch Disc, Pressure Plate and release bearing for the 2.0
    P-up is currently at 90k orig miles and clutch is beginning to slip. Clutch cable has been adjusted.
    Thanks
    Steve
    What do you mean by it does not fit? The pumps for the g52b and g54b are the same as long as it is for a 79 - 81 motor, as is the valve cover gasket. You can make a new carb gasket from gasket paper using the old gasket as a template. If the gasket doesn't fit, there is a problem with the valve cover, like the cover was switched with a different motor, maybe a 2.0 l Colt car motor. The A/C dryer should be a standard part - the dealer installed unit is most likely a lone star or frigette unit sold through the dealer. Post pics of all the parts you have issues with and we will help you figure it all out.
    Nor Cal
    Hi Pennyman1,
    Here are the pics. I dont think the engine has been switched.Click image for larger version.
ID:	13879Click image for larger version.
Name:	EGR Thermal Control Valve.jpg
ID:	13880Click image for larger version.
Name:	V-cover gasket.jpg
ID:	13881Click image for larger version.
    Nor Cal
    Here are more pics.Click image for larger version.
