Replacing front lower control arm bushings 2wd
Can anyone give me any ideal on how difficult it is to replace front lower control arm bushings on a 2wd 1996 mighty max? I have had multiple alignments and still having front end issues. It is at the point now the tires are howling going down the road! lol. Thanks in advance!
Masters Degree
Read through the Haynes manual procedure and the Factory Service Manual for the 1st Gen, which should be almost identical to a 2nd Gen, to get an idea of how long it will take. Varies depending on experience and tools.
http://www.mightyram50.net/vbulletin...er-216-Manuals
