Results 1 to 5 of 5
Thread: power steering gearbox
    Big Rapids, MI
    1983 Dodge D-50
    4D55-T
    Hi all has anybody had a power steering box go bad or at the most get a little sloppy mine likes to wonder a inch or two while keeping in lane tried tighten the top jam no difference thinking its wore out thanks
    yes - the pitman arm bearing goes bad and causes slop in the shaft. No easy way to repair it; if you have a 2wd a starquest steering box will work in place of the truck one.
    Big Rapids, MI
    1983 Dodge D-50
    4D55-T
    thanks for the reply
    Grants,NM
    1985 Dodge D-50
    Chevy V8
    hey, check the pitman arm first.
    United States
    4G63
    Are there 2 seals on the output shaft that the pitman arm connects to? Mine is leaking.
