stereo takes long to turn off?
Wondering what's making my stereo shut off a little longer than it should? Usually truck goes of an stereo goes off with it but lately it hasn't been doing so. I shut off truck and a minute or two later stereo shuts off. What wire should I check? Or fuse?
Sophomore
Factory or aftermarket stereo? Assuming it's aftermarket, be sure your power/12V is going to the ignition wire, specifically the Accessory wire of the ignition. I can't recall what color this wire is (I just had my radio out last night too, damn), but do a quick google search or dig around here for the factory wiring diagram for the radio.
Hope this helps?
I believe its a thick yellow one. You think that's the one that causes it? I'll look into it and update thanks
Okay so I cut the 12v power cable and retaped it don't still turns off a Little later.
