Results 1 to 5 of 5
Thread: distributor wiring color help
    Apache Jct,AZ
    1991 Mitsubishi Mighty Max
    Hello, fixing a friends wiring its on a 90 4g64 and the harness got melted right at the plug where the main harness meets with the distributor harness problem is i can't seem to find any diagrams that show the wire colors after the plug pretty strange it they all only show the wire colors on the main harness, the distributor side have different colors so i just wanna make sure i match them correctly. Thanks.
    Las Vegas, NV
    Black - Ground
    Brown/Green - Crank trigger
    Brown/Red - Cam trigger
    Black/White - power
    Apache Jct,AZ
    Quote Originally Posted by Merrill View Post
    Black - Ground
    Black/White - power
    I need the colors on the other side of the plug of the ones you posted
    Las Vegas, NV
    Black - black
    Brown/green - yellow
    Brown/red - white
    Black/white - red
    Apache Jct,AZ
    Thanks huge help i'll update when its running again hoping no damage was done to the ecu.
