Quick update. The motor is getting dolled up and the oil pan pictured above most definitely will NOT fit. Had to get a used one from a junkyard (by god was that junked ram 50 a goldmine! Got everything that I thought I had to fabricate right off a factory truck). On that note, don't order an uncommon oil pan from O'riellys, because they are a pain in the ass to return. Just find a junker to strip.
Oh, and here are a few pictures for those who like pictures. First is the motor as it was yestrday with the CORRECT oil pan in the background (note the dramatic indent for the front pumpkin), and the second is my attempt at making the ugly intake manifold more attractive. I'm going to block sand the raised "V6 3000" back to raw aluminum when the enamel cures.
While I've got the engine out I'd be happy to take a picture of any component on it or the truck upon request. If you need pictures or measurements for anything you have maybe two weeks to ask me to get them for you.
