Results 1 to 8 of 8
Thread: 1985 2.6L bogging down on acceleration
    Nashville, TN
    Runs fine if I accelerate very slowly. If I speed up too fast it sputters and loses its get-up-and-go. P much gotta be air or fuel right?
    Im a 350 guy....and on those it's usually fuel filter. Replaced that with no improvement. I'll try to get a vid posted on YouTube and provide a link.
    sheffield, vt
    1978 Dodge D-50
    yes could be air or fuel (i am under the impression you replaced the air filter since you mentioned it but did you check the in tank filter to see if it was clogged-although fuel probably NOT an issue according to your last thread) or could be: timing, wires, plugs, cap, rotor, coil, vacuum leaks, clogged catalytic, improper engine operating temperature, choke not fully off....this list could go on but i'm too lazy. it has the original carb setup?(verify choke is off, if not check out: http://www.mightyram50.net/vbulletin...-for-smog-Help )...& what else has been done...yes pics or vid would help & any other symptoms would help ie-operating temp, condition of plugs, starting issues....
    Nashville, TN
    Original carb set up. Will verify choke.
    Nashville, TN
    Air filter Is good, fuel supply seems adequate, timing is spot on, operating temp is normal, new plugs. Cleaned the carb, checked the wires, checked for bad vacuum lines. Hadn't messed with anything when the problem started, just cranked and had the issue one day.
    Vanessa, Ontario
    1989 Dodge Power Ram 50
    If it was just a one time problem could it possibly have been vapour locked?
    Nashville, TN
    No, it's an ongoing problem. It runs fine at certain RPMs. (No tach so I'm not sure the specific range)
    Vanessa, Ontario
    It might be the accelerator pump has quit. You might not be getting that squirt of gas when you snap the throttle down for fast acceleration and the engine is starved for fuel. When you ease up on the throttle does it smooth out? Is it possible that it starts to bog down when the secondary starts opening? If the secondary jet is clogged up it will be starved for fuel when it opens.
    Look down the carb as you spin the throttle and look for the stream shot of fuel from barrel sides. Check fuel filter. Check your advancing on your distributor. Make sure the weights advance correctly. Pull hose from the carb end and take off the distributor cap, suck on the hose end and watch to see if the distributor turns as it tries to advance the rotation.
