Truck was running fine until I replaced the fuel pump. It had a pin-hole leak in the side.
I can hear the fuel pump actuating when i turn the motor over, but no fuel is being pumped through. I put a little suction on the IN fuel line and gas flowed out easily, so I know its not an issue between the fuel pump and the fuel tank.
Gotta prime them somehow? Any thoughts?
