Results 1 to 8 of 8
Thread: Hi From Nor Cal
    Suisun City CA
    Cool Hi From Nor Cal
    Hi Forum!!! My name is Nick I have a 1990 MM 2.4L 5SPD 2WD. Got the truck for dirt cheap to be a daily driver, truck runs great did a basic tune up on it. Is there any concerns I should have about the truck or need to look out for? I would like to do little things to the truck to "make it my own" I would like to get a little more power out of the motor, and try to lift it a little ( I haven't seen anything for this).
    Richmond, CA
    Welcome. There's tons of information about lifting it and some performance mods you can do to the 2.4 in the Suspension, 4x4 and Performance Mods forums. So search around a bit. Always nice to have another NorCalian on the board.
    "Keep 'em on the road."
    See what I have for sale:
    http://stores.ebay.com/zims
    Suisun City CA
    Thank I will look into them forums.
    Jacksonville, FL
    G54B-T
    Check your timing belt/ balance shaft belt and associated components behind the timing cover. Keep your cooling system in good order. Too many of us have suffered broken belts from lack of maintenance and cracked cylinder heads from overheating the engine.
    Richmond, CA
    Yeah, re-torque your cylinder head bolts to spec 50 and/or 500 miles after the head comes off for any reason. Apparently not re-torqueing after so many heat cycles can lead to blown head gaskets and cracked heads. Keep your cooling system flushed and clean.
    welcome to the site, I'm a fellow Solano county member. I would definitely recommend new timing and balance shaft belts along with all associated pulleys and tensioners. Besides that with normal mnt. you should be ok.
    Josh
    09 BMW 335i E92 Twin turbo
    Suisun City CA
    Right on thanks guys. Hey DroppedMitsu I think you know a buddie of mine Brandon Anuzzie.
    Oh yea I know Brandon, havent seen him for a while. Small world
    Josh
