89 mm filler tube
Does anyone happen to know what size the hose is that goes from the filler neck to the tank? I have an 89 mighty max. Any point in the right direction would be greatly appreciated. Just trying to avoid crawling under it right now.
Call up auto parts store and ask them to check for part (hose) and they can give the size to you if your in a hurry. Not positive right now on the exact size and I also don't want to crawl under my truck to check.
Here is a part number MB504933, try googling that and you'll find them.
Bachelors Degree
measured 2 inch diameter on my 90 model.
