Results 1 to 22 of 22
Thread: Really High Idle at Start Up
    Denver, CO
    Thanks Pennyman! I might start another thread to ask if anyone else (hopefully in CO) has had any such luck passing emissions with the weber carb.
    Here's my list of parts to order. If anyone sees anything I'm missing to convert over to the weber, please chime in.
    1. Weber 32/36 Carb from http://www.redlineweber.com/carb-kit...hrysler-dodge/
    - I'm going to call to speak to a rep directly but, any advice between the DGEV (electric choke) vs. DFEV (manual choke)?
    2. Electric fuel pump
    - Sounds like the Carter is loud as hell and I think it was 'originalowner' mentioned the Airtex E8004 is a much better option, thoughts?
    3. Fuel Pressure Regulator - Holley 12-8004 (pressure range 1-4)
    - From what I understand this is optional, but I'd like to hook up a mini gauge to this in order to see what my pressure is.
    4. Block off plate - Does anyone know where I can buy one? I don't have a grinder (yet) to cut my own out of sheet metal.
    Am I missing anything?? Thanks for your support!
    Denver, CO
    Just ordered my new carb from redline weber. The guy I spoke to said no need to run an electric fuel pump, just a fuel press. regulator. Any input here is helpful? I'm trying to get all my parts ordered to get the new carb on this weekend.
