I've only had to use it twice to get it started because once it starts the first time. It doesn't need it after that but I'll stop spraying fluid into that, I didn't know that could happen. Ill take your advice and start with the mechanical adjustments and checking sensors, still learning a lot about these trucks as this is my first one. Thanks for the Info!
