Results 1 to 5 of 5
Thread: Horn Wire Color in Steering Column
    Charlotte NC
    Ok, Hooking my air horn switch to the factory horn button this weekend, To save myself some time. Does anyone know the color of the factory horn wire coming from the column?
    Thanks,
    Just splice it in at the old horn wires - use a relay to switch the power to the air horn off the battery - the wiring in the column is not up to any high draw loads such as compressors, large solenoids, or older car and truck horns.
    Charlotte NC
    Just as a heads up, I worked in the 12volt industry for over 8years as both sales and installation. I appreciate your candor on how you would do it. However, I have already correctly wired the compressor as well as plumbed the air lines. Everything is fused as well as ran off a dedicated 12volt switched power to save me from a dead battery should the tank have a leak while parked.
    All I asked for is the wire color coming from the steering column for the horn. Reason being, the horn button when pressed creates the ground I need to close the switch to open the solenoid.
    I apologize for not explaining in detail my installation or why I was needing the wire color.
    That being said, Does anyone have or know the wire color for the horn button coming from the steering column?
    It is your lucky day - I just got a factory set of manuals for an 89 Ram 50. https://drive.google.com/file/d/0B1j...ew?usp=sharing I did not know your level of experience with wiring - I was answering it at a newbie level. Hope this helps!
    Charlotte NC
    Your AWESOME Pennyman!!! That's why you have the juice on the board!!
