Get pig tail fuse holders and solder them to the tabs to fix the fuse holder issue for now. The permanent solution is to replace the whole block. The bar across the back of several fuse holders is just a common buss bar - wire can be used in place of it. Just be sure that you use the same or heavier gauge wire when tying the fuses together. That is only an hour or 2 job if you can solder, or they also sell fuse blocks with crimp terminals or set screws that use blade fuses.
***SQUEEEE*** I could just hug you !!!! THank you thank you thank you!!!! Yeah, I can solder but I'm one of those people that probably shouldn't because don't understand circuits too well it takes me a long time to understand though I can eventually get it... or at least think I do. Saw the bar on the back & freaked! There's an order they need to be in?! Uh oh. Not a quick job after all. Crap I didn't even know it was OK to use wire instead of that bar! SWEET!
Just got back from the store (again) and bought some tab pieces hoping I can make it work, but didn't know about the pig tail fuse holders - well, I saw them but didn't know what they were for. Oh, the noobie in me is overflowing haha! Lots more reading to do, thank you so very much!
