Results 1 to 6 of 6
Thread: 88 ram 50 questions
    massillon ohio
    88 ram 50 questions
    well since i dont know much about these trucks i figured id ask are there any certain things to look for, or any major issues. and also are there any places that rot out or rust bad that i need to be on the lookout for any feedback is appreciated. anything you guys think may be important
    ,john
    sheffield, vt
    1978 Dodge D-50
    not sure about specific locations on a 2nd gen. however on a 1st gen the cab (mounts...especially the front) show signs of rust long before the bed does
    #1 thing...Do not over heat the truck...any sign of a strange hike in water temp, turn it off and roll to the side of the road fast. I use a 180 temp thermostat cause I am a paranoid owner.
    Keep your timing belt checked, 60-80k miles and snap! They are cheap to replace.
    Change muffler bearings if they start making exhaust sounds.
    Charlotte NC
    What about the dreaded headlight Fluid rotation!! These trucks are horrible about that!!! The stealership only has the correct weight fluid anymore!!
    sheffield, vt
    1978 Dodge D-50
    in new england everything rusts like its on fire...i have my trucks sprayed with a heated combination of bar & chain oil mixed with wax...they charge me 60/small http://www.mightyram50.net/vbulletin...hp?albumid=301 vehicle & 80/large http://www.mightyram50.net/vbulletin...ow-flinksander.
    Awesome Plow you have there RRTT. Reminds me of the Railway plows.
