Results 1 to 5 of 5
Thread: Releasing Fuel Pressure - Alternate method?
    Atlanta GA
    1991 EFI 2.4L. I need to replace the head gasket, so obviously I need to pull the head. So, I got the truck into the garage to start the disassemble process. Even though I have a repair manual, i neglected to pull it off the shelf for a while. Some things just seemed like obvious start points. Well, I goofed. I forgot to release the fuel pressure.
    Manual says I need to unplug the fuel pump, then run the truck till it dies. I can't do that without spending quite a bit of time undoing quite a bit of work. The distributor is out, and all of the wiring harness, including the fuel injector connections of course.
    So, is there an alternate way to do this? If I had a locked up engine, I couldn't follow the manual's prescribed process, right? So, how do I release the fuel pressure without counting on the injectors to do it for me?
    It goes without saying, but I'd rather not blow myself up!!
    Orlando, FL
    G64B
    you can remove the fuel line going to rail,undo the bolt and remove the line slowy
    Atlanta GA
    Any idea how much fuel I need to be ready to catch? Will a wad of paper towels do, or do I need some kind of cup?
    Maybe put the paper towels in a cup, lol. Your probably not going to get much, if a cup at all. Lay a rag around the opening so it doesn't shoot you in the eyes depressurizing. After it releases pressure you may get some residual fuel which can drip into a cup or a couple rags. Don't arc the battery terminals by accident either.
    Colorado Springs
    when i unhooked the lines on my 95 2.4L i simply cracked loose the high pressure line there was almost no fuel spray it leaked less than 1/2 of a cup of fuel. A few shop towels or rags will be plenty to catch the fuel spill.
