Results 1 to 9 of 9
Thread: Lifter Tick For The Dummies
    Atl, GA
    '94 MM 2.4L 4cyl
    My truck has always had engine tick. I remedy this by keeping the oil fresh and filled and this usually fixes the problem. However, this morning it was ticking a lot more than usual so I went ahead and changed the oil (last change sept). It did not help. The truck is now ticking at idle and at speed, hot or cold, highway or driveway.
    I don't know if this is an oil pressure problem or a valve problem. My Haynes manual suggests improper valve clearances, or worn piston pins or piston pin holes, or yes even a collapsed lifter, but unfortunately it doesn't supply that much visual information on how to check and/or fix these things.
    What is the best way to go about diagnosing this? I am going to check the oil pressure and pull the valve cover tomorrow but I need to know what to look for.
    Anyone else have a similar issue?
    Any help is appreciated.
    Richmond, CA
    I'm learning how to do this myself because I have the same issue. What I've found is to inspect the lifters, unbolt the 10 (I think) 12mm bolts you see. The cam assembly will lift out. The lifters in the rockers should have firm but smooth spring action. If they're stuck, they should slip out of the machined pocket with a little effort, they're held in by tension. You can either try cleaning them to see if they come unstuck or replace them. They're around $8-10 apiece at parts stores. I'd soak new ones in oil and work the oil into them with the spring before reinstalling.
    Be careful with cleanliness so the journals or bearings don't get grit in them. Remember to torque everything back to spec.
    "Keep 'em on the road."
    See what I have for sale:
    http://stores.ebay.com/zims
    you can also soak them in either kerosene or charcoal lighter fluid to clean the gunk out of them, then soak them in fresh motor oil or auto tranny fluid before you reinstall them. Be sure you put them back in with the holes up on the lifters.
    Watertown, NY
    1993 Mitsubishi Mighty Max
    Have the same problem with my truck. Its quite a bit louder than when I first got the truck, which was in March. and I've changed the oil twice so far since then. Are there any pictures available of the rockers underneath the valve cover?
    This is a common issue for most engines running hydraulic heads/lifters. Give this a shot -
    http://www.mightyram50.net/vbulletin...ll=1#post49688
    support the forum that supports you - join and donate to MightyRam50.Net Get perks and donations $15 USD and over receive official MightyRam50.Net window decals
    Watertown, NY
    Is it possible that the lifters are our of adjustment. And how hard arw they to readjust.
    hydraulic lash adjustors are not adjustable - they pump up with oil pressure. Sludge can gum them up and they will stick and then tick. That's why cleaning them out can fix the issue - or replacement will work as long as the rest of the motor is clean.
    Watertown, NY
    Oh ok. Thank you. I think Ill try that diesel gas trick for an engine flush then. A bit skeptical on putting gasoline in my oil, but if its supposed to work. . .
    Quote Originally Posted by Yoshiwarrior View Post
    Make sure it's diesel fuel - you don't want combustible hydrocarbons like regular gas in there that lack their own inherent lubricants and detergents. I guarantee the diesel flush will cure noisy hydraulics - I was skeptical too (what a freakin' stupid idea of 'watering down' engine oil, it'll damage the bearings and seals...) but I have not only used it on all of my higher mileage engines very successfully, but have come up with what I think is the most effective flush technique to prolong oil life and free up lifters. My hung dog (Hyundai) is due for a full flush this weekend...
