Results 1 to 3 of 3
Thread: Valve stem seal help!!!!
    Bell Buckle, TN
    1991 Mitsubishi Mighty Max
    I have purchased a FelPro HS9388 pt head gasket set and it cane with two different types of valve stem seals. 4 of the typical metal skirt with seal spring at top and 4 that look to be all silicone with 2 metal rings around outside. My question is which is exhaust and which is intake!
    Bell Buckle, TN
    SS72630 is the Fel-Pro seal set. there are 4 standard type for INTAKE and 4 that are black rubber with steel rings for EXHAUST valves. Maybe this'll help when someone else does the Head set (HS9388 PT) or just seals.
    Can you post a picture of the 2 side by side for us.
    Check out the Fear Monger by
