Originally Posted by
pennyman1
harbor freight 24" 1/2 drive breaker bar should do the trick - slide a pipe on the end if it still won't come loose. With the auto, the parking pawl should hold it good enough. The impact wrench would be the best bet - hf has a 1/2 drive earthquake model good for 700 ft lbs of loosening torque. The bar or the impact should be able to get it tight enough to stay on.
