Sophomore
Removing carbon buildup within exhaust manifold
There must have been a valve or ring problem ( ? ) with the engine that my "new" exhaust manifold came from. Three or four little "mountains" of carbon were sitting in one of the engine-side ports. I scrapped those off, but is there something I can run through the ports to remove such carbon build-up that might still be there but which I can't see? THANKS. /ChristopherASA
