Results 1 to 15 of 15
Thread: Super Cheap AND Easy upgrade that is AMAZING!!!
    They should just come apart. In original lamps there should be a foam seal between the body and the lens. Repos don't have that.
    Have a close look, they are probably just stuck with age. But perhaps someone has silicones them up. Some warm water and a flat painters blade might help
    New Providence,PA
    4G72
    Thanks...i will look at them closer and see. May be repops. Ill let ya know.
    Quote Originally Posted by Cchuckster11 View Post
    Go easy on them if they're repro assemblies. The lenses on them are really thin and they won't take a hit like the OEM ones. If some genius has sealed them together with a bead of silicone, it's going to suck separating them... (they weren't exactly water tight so it wouldn't surprise me)
