Results 1 to 7 of 7
Thread: Carpet
    Clovis, CA
    Carpet
    Just wondering who makes a good quality carpet kit for my 88 MM MacroCab. My stock carpet is starting to look a little like a sun-dried coyote carcass. Also, when I remove this carpet, is there something I should know about the floor shift boot? Do I just pull it up and over? Or is there some sort of bracket holding the rubber boot on? This is an urgent upgrade as I believe that a dying raccoon with a kidney infection crawled in a few nights ago and relieved his bladder...
    Charlotte NC
    Clovis, CA
    Thanks!
    Any tips on getting the carpet off and over the floor shifter? Or is it fairly self explanitory?
    Online
    there should be a ring that screws down to the tunnel that hold the boot in place. Or cut the carpet off around the boot to remove it. It may be that so much has been spilled on the carpet that it is glued to the floor by goo.
    Quote Originally Posted by SkaBoss View Post
    Did Mitsubishi factory install that custom coyote carpet, Sorry I couldn't help myself on that one.
    There are kits available. Though I would worry about installing new carpet in fear that the ole saying, "Does a bear shit in the woods" could end up on a fresh carpet install , next to the raccoon juice. Maybe you need to roll up your windows at night to keep the coyote and raccoons out of the truck.
    Vanessa, Ontario
    1989 Dodge Power Ram 50
    Ive been looking for carpet for my '89 4x4 with the extended cab. The only ext. cab carpet I can find is for the 2wd. Carpet for the 4wd seems to be available for the regular cab only. Does anyone know if carpet is available for 4x4 ext cab?
    Charlotte NC
