Results 1 to 11 of 11
Thread: What rims will fit?
    Hawaii
    What rims will fit?
    I'm new to the forum...I have a question regarding rims that will fit my 91 dodge ram50 2wd. Is there any rims that will fit on my truck without boring the center hub. I'm not talking about custom rims, I'm talking about other makes of rims. For example (toyota rims, chevy rims, nissan, ETC.) I want to buy rims second hand due the fact that I'm on a tight budget. I will appreciate any help.
    Atlanta GA
    Almost any 6 bolt pattern from Nissan, Toyota, Isuzu, etc, will fit with no modifications needed. I am currently running a set of 15x6 wheels from a late 80s Isuzu Trooper. Scored them off Craigslist for $80.
    Previous owner had a set of aftermarket wheels on the truck that fit bolt pattern wise and center bore wise, but the offset was not correct. The wheels extended way out beyond the fender wells, and it made the steering squirrelly.
    the major issue is the center bore - 95 to 108 mm is what will fit without boring. Back spacing is another issue - stock backspacing is 4 1/2 to 5 inches - depending on wheel width, less back space pushes the wheel out past the fender. 87 or older GM truck 6 bolt wheels have the large center bore, but may not have the right offset.
    Hawaii
    Okay...thanks for the info. ....what I'm trying to do is get me some 15 x10 rims and put on a 2/3 inch drop. I like the stocky wide look. Can anybody kind of guide me in to the right direction of buying the right rims with the right backspacing and offset(all I need is numbers, I don't expect anybody to browse the web for the right rims for me). I would like the tires to stick out but, Is two inches of drop too low that the tires will rub the top of the side fender or rub the fenders by the bed?
    Do you really want the Hot Wheels look - that went out a long time ago, will beat the sides of the truck up, and may also be illegal in your area.
    Kingston Springs, TN
    Yeah, I'm doing 15x10's on my 2nd gen and its deff going to have to have fender flares. These trucks do not lend themselves to wide wheels very easy. The hubs are almost at the fender line on then
    Rockledge, PA
    Also, if you find rims cheap enough, boring them isn't to bad. I paid $40 per rim, and I may have paid more than I should have. Sounds like people have paid less
    Oakland, CA
    15x10 may give you a steamroller look while screwing up handling (tramlining) and make steering feel unpredictable. My truck came with a set of 15x8 alloys that were wide but didn't look silly. Poked out from under the fender tastefully, like 1.5". Fitment was perfect and didn't come close to rubbing with a 2/2 drop. Personally I like steelies and skinny tires so I took 'em off.
    Tulsa, OK
    College Place, WA
    Has anyone tried rolling the fender lip in? I have been thinking of doing this for awhile so I can run a wider wheel closer to the fender without cutting into the tires. I really like the wide tight look.
    College Place, WA
    I just saw the post from fordsubishi where he rolled in his fenders. looks really good. pg6 of the build.
