Results 1 to 6 of 6
Thread: Compression check
    Lytle, Texas
    1985 Mitsubishi Mighty Max
    Compression check
    Hello from South Texas. Does anyone know what the PSI range is for compression checks? Just picked up a 85 4x4 MM in a trade and need to start evaluating what I have to work with. Any help appreciated.
    Jacksonville, FL
    G54B-T
    looks like 140 psi
    Lytle, Texas
    Funny there isn't a plus or minus associated with that, most others have a 14 psi variance. Go figure. Thanks for the help.
    Ca
    1993 Dodge Ram 50
    First,
    Welcome Sir !!!!
    Second,
    May I ask for an bit more info? Specifically, Your Engine hot & cold compression readings?
    Lytle, Texas
    Thank you for the welcome. I don't have any compression readings yet, armature is bad on the starter. I can only get about one and one half turns on the engine before it spins out. More to follow as soon as thats fixed.
    Jacksonville, FL
    G54B-T
    Compression is bound to be low on an old motor. The thing to look for is a big difference between cylinders.
    Make sure your cooling system is adequate because overheating these engines usually leads to cracked heads.
