you don't need the slave cylinder with the cable clutch pedal. We are the only ones crazy enough to go all out for these trucks - thats why there is so much knowledge and info here. Clutch assembly should be the same, but measure the clutch disk - truck stock is 225 mm later trucks have 240 mm clutchs which is better.
