Results 1 to 18 of 18
Thread: Will it fit?
    Phoenix Az
    Will it fit?
    Hi guys, I'm in the market for a M/T for Ramona my 87 Ram 50. My question: will a km145 out of an 85 Montero fit? I found one reasonably priced
    Grants,NM
    1985 Dodge D-50
    Chevy V8
    hey, does the engine match?
    5 speed 4wd g54b wide block.
    Phoenix Az
    Yes, the monty has the 2.6 like mine does.
    but is it a manual tranny in your truck? 87 all 2.6 motors should be wide blocks, but with the age of these trucks you can never be sure. Swaps are done all the time - I found an 86 ram 50 in the upullit, the firewall said g63b, but the motor was a g45b auto.
    Phoenix Az
    It is a manual also and includes the transfer case. But Ramona has a cable clutch, the Montero has a hydraulic clutch. Will that be a big deal? My tranny took a . Maybe I can steal internals
    Phoenix Az
    Here what the input and counter shafts look like
    Phoenix Az
    BTW thanks guys for jumping in on this with me
    if you pull the slave cylinder off - the cable will go through the hole in the bell housing and hook to the arm. Be sure to get the shifters with the transfer case - they could be different from the truck.
    Phoenix Az
    Thanks Pennyman1. So I would also need the slave cylinder and clutch assembly not only the tranny itself? Sorry if this topic has been discussed in the past. I have not found any helpful info but here
    you don't need the slave cylinder with the cable clutch pedal. We are the only ones crazy enough to go all out for these trucks - thats why there is so much knowledge and info here. Clutch assembly should be the same, but measure the clutch disk - truck stock is 225 mm later trucks have 240 mm clutchs which is better.
    Phoenix Az
    Thanks for the input. I know what you mean by "we are the only ones crazy enough", thats the look people give me when I ask for a part at any given place.
    I imagine I would need the throw out bearing from the hydro as well? And o dont completely understand what arm the cable hooks to.
    Phoenix Az
    Here's a pic of each
    Phoenix Az
    Do you mean "throwout lever" when you say arm? I've never dealt with a hydro clutch.
    you would need to swap the arm from your old tranny in place of the one on the montero tranny - throwout bearing may be the same, but you could use the montero one.
    Phoenix Az
    Awesome, I was able to pick up the tranny so now I can put theory to action. Ill be working on that this weekend and will give progress reports along the way. Thanks a mill.
    Phoenix Az
    Prep for KM145 swap
    So got under the truck to drain the tranny today, and the fluid was light at first but it got darker as it went on. I decided to drop the pan.
    And this is what I saw..
    Notice the gold flakes? Those syncros
    Phoenix Az
    Im back. Long story short, i couldnt figure out how to incorporate the cable clutch arm to the hydraulic clutch bell. I've decided to go with hydraulic clutch for comfort and ease. The main gear is shot on mine and I don't really want to put any more knotches on my "km145 breakdown" belt. I've had practice but have lent out the wrenches I use. Crescent and monkey
    Boise, ID
    1984 Dodge Power Ram 50
    4D55-T
    Can anyone show me how to convert the hydro to work with the cable clutch system? I noticed earlier that pennyman mentioned about putting the cable through the bellhousing hole. But what do you hook it up to? Thats what I'm trying to figure out, I have both transmissions out and trying my damn hardest to figure it out but I am stumped and need help.
