Results 1 to 3 of 3
Thread: Power Steering Pump - 92MM 2.4 4G64
    Winter Park, Florida
    Looking to get a new Power Steering Pump for my 2.4MM. I would like to get one that will last a while, preferably a nicer one than an OEM replacement, but I totally understand if there isnt much in the way of options. What can you guys recommend?
    Also, if you have any tips for fixing dethreaded holes, that would be great. On the mount for the power steering pump, it has the three bolts on the inside and the one on the front. Two of the inside ones have stripped the holes. With the one thats left and the front one still good, it holds tight, but I am afraid to leave it like that for much longer. :/
    WA
    My remedy for stripped out threads is to cut new threads the next size larger. Having a metric tap and die cutting set and can of cutting fluid has been very handy for me. Our local hardware store has a board with labelled nuts and bolts to check for the right sizes and I just go from there.
    1990 MM 4x4 3.0
    1991 MM 4x4 3.0 Diamonte
    Just another remedy my mechanic used back in the day is Helicoil. http://www.helicoil.in/
