Results 1 to 3 of 3
Thread: I did a dumb thing...
    South Carolina
    ...and removed by distributor without marking the alignment of the rotor. This is on a 1990 with the 2.4 FI engine. What do i need to do to make sure the timing wont be off when i re-install the distributor?
    Columbus, OH
    Put the engine at TDC on the #1 Cylinder (Cam and Crank marks set),put the rotor on the Distributor to point at the #1 Position on the cap (remove the cap and paint a line on the base with white out). install and time the motor according to the manual...
    Georgia
    1984 Dodge D-50
    4G63
    ^^^^^^what mike said^^^^^^
    That's the same engine as mine.
    If you're not sure of TDC, pull the no.1 spark plug, and see if you can see the piston.
    Easy~~peasy
    ~~~~~~My toys~~~~
    1984 Dodge D-50 (Daily driver, when raining)
    1990 Mitsubishi Mighty Max (Trying to figure out no power and sputtering)
    2006 Harley Davidson Heritage Softail (Rider when it's not raining and cold)
    1975 Honda CB750K5 (Rider when it's not raining and warm)
    1974 Honda CB350F1 (In paint for tins)
    1972 Honda CB175K6 (Just a rolling chassis, no engine)
    1972 Honda CB100K2 (Needs an engine, and rebuilding) (shhhh...if wife knew I had this, she be pizzzed)
    ~~~~~or headaches~~~~~
