Hi everyone, I'm still pretty new to this website and even newer to forums. I've got an '89 Ram 50 with new developments in the idling arena. The old girl always idled pretty good for me. Every once and a while she would idle high for no reason. I would rev her pretty high to try to get her to settle down with the idle without success. I would then shut her down and restart to the same thing. Nothing but randomness seemed to change that idle issue but she would always idle fairly smooth. Now she will start OK and idle but when I rev the engine over about 1,500 she idles down, lopes real bad for about 10 seconds and dies. The timing is about 7 degres BTDC which is where my altitude dictates it should be. I'm thinking the dashpot and choke SAS screws need to be adjusted but I dont have a tachometer for the dashpot adjustment and wanted to see if anyone has had a similar issue but more importantly any success in remedying the situation and some turn counts to start the choke and dashpot SAS screw setpoints from. This is the only transportation I have and the wifes car is having to drive 100 a day to take me to work and back. I dont have funds to drop a Weber in as most posts suggest to do. Any help with this issue would be greatly appreciated. While I appreciate the responses I've gotten from another post about this, they seem to lack specifics relevant to my issue.
Thank you for reading this!
