Results 1 to 25 of 121
Thread: The Rat B@stard Max: A Tale of swapping, modding, building, and adapting....
    Kingston Springs, TN
    I know right! I though it might have been the tranny cooler at first but that cooler is on the other side of the core support still hooked up
    Quote Originally Posted by thehive View Post
    not to quote myself, but no it is not the tranny cooler, the tranny cooler is still hooked up on the other side of the core support
    and the lines cut going to the transmission
    all the lines go thru the fire wall to the passenger side of the engine bay, where the power steering pump and reservoir are located on the motor.
    i also looked into getting the factory oil filter housings that had the ports made into it for the factory oil cooler lines but since it's for the FWD family of motors it won't work on ours so looks like i'm stuck using a sandwich adapter after all
