Hi, got any 89 Ram 50 with the 2.0 2bbl. I've had issues with power but the idle has been pretty good. Without messing with the dash pot or choke SAS screws she dies when she idles down. Timing was about 7 BTDC. I'm hoping someone has some starting points for how many turns to set the SAS screws at so I can eliminate those as issues. I'm also thinking the dash pot might be main problem. The kicker is she'll idle great but when I rev her up over about 1,300, she dies when she gets to normal idle. I don't have a tach of any kind that works and the Haynes dash pot set procedure calls to monitor revs and make SAS adjustments at specific RPM's.
