HI
I got one of these Ram50's about 10 years ago and except for a clutch did nothing but change oil. I did the timing belt and balancer belt several months ago and then I blew the head last month. Turns out I had a bad water valve in the heater and I probably had air in the system. Changed out the heater and new radiator. Its finally running and I want to fully drain the coolant before running it for much longer with the dregs of the old dirty oily coolant in it.
In the Chilton's it says to do so out of the block drain plug but as usual fails to supply a picture or diagram.
Anyone know where this plug is?
Thanks
