Hello, any help is appreciated. My '94 2.4l is a great little truck but recently it has been acting up.
1. When turning the wheel (particularly to the right) at slower coasting speeds I'm hearing a high-pitched wailing/moaning sound. I replaced the power steering fluid about 6 months ago and it is still at a normal level (and clean). I'm only hearing the sound at slower speeds, and it sounds like it's coming from the front, but it's difficult to be certain. It also seems like it only does it after the truck is warmed up. What could this be if not the PS fluid? Should I drain the fluid just to be sure?
2. I've replaced most of the front end suspension (and 4 tires) with hopes that it would tighten up my steering but alas the wheel is still wandering, especially at highway speeds. Turning the screw in the gearbox made the wheel tighter, but the truck was harder to control because it would wander and it took extra effort to straighten back out. So yada yada yada now I'm committed to replacing the gearbox. RockAuto seems to have the best prices but I'm wondering if anyone knows of better deals on mits parts?
