Results 1 to 3 of 3
Thread: Vacuum advance
    Sidon,ms
    Vacuum advance
    Where should the vacuum line from the distributor be connected?
    Thanks
    ZZ
    to a port on the carb above the throttle plates for ported vacuum - this will supply a higher vacuum as the throttle is depressed, unlike the manifold vacuum which it high at idle and drops when the plates are opened.
    Sidon,ms
    That's it thanks
