Results 1 to 8 of 8
Thread: Rear Sway Bar???
    Ca
    1993 Dodge Ram 50
    Rear Sway Bar???
    Succinctly, Interchange into '88 Ram 50, ???
    Thx in advance Honored posters.
    My ex-wife has one but she uses it daily. Says a girdle hurts her chest hair.
    There is no rear sway bar that will swap over from what I have seen. But you can add in an after market one. http://www.1speedway.com/
    Check out the Fear Monger by
    Las Vegas, NV
    1991 Mitsubishi Mighty Max
    Montero Sport rears do. It's not necessarily "direct" (as in bolt-on), but it isn't terribly difficult to install. You just have to weld brackets.
    Ca
    1993 Dodge Ram 50
    Humble Thx Sir !!!
    Ca
    1993 Dodge Ram 50
    Humble Thx Sir !!!
    EDIT, SIRS!!!--- MR camoit, & Mr Merrill.
    There is a thread on here that someone used a rear sway bar from a late model F-150. Someday I may get around to mounting the one I bought for Geronimo years ago that was supposed to have been made for a 1st gen D-50. When I tried to fish the u-bolt through the frame for the mount, it hit a reinforcement in the box frame that stopped me from mounting it that way. Drilled all the way through from the bottom, but it didn't work right - kept binding. Was going to make plates to mount to axle, just never got around to it yet.
    http://www.mightyram50.net/phpbb3/viewtopic.php?p=13114
    Something about the ford sway bar? In our archives.
    crvtec90 wrote:
    TurboMax put a rear sway bar from an older F-150 . The rear axle has brackets that wrap around and hold the bar but you have to come up with some way to mount the endlinks to the frame.
