Sophomore
tach cluster
what wire on the back of the cluster plugs is for the tach? im gona wire mine directly to the coil -. thanks.
Senior
It should say on the circuit board on the back of the cluster. just match it to the right pin on the plug.
Sophomore
Hey I think I took that picture way back in the mightyd50.com days lol
Sophomore
ya i found that thanks. but instead of putting a ring terminal on the screw i just taped into the white wire and ran it to the coil works good. on a side note though my oil pressure guage doesnt work. i switched out the sending unit from the truck i got the cluster from at the junk yard.
Sophomore
yep. I converted some old threads from the old, old board into pdf files. I had to extract pic from my pdf file.
Miss all the lost info from the original board.
