I just had my 1994 clutch replaced, and after 1k miles, the cable snapped. The mechanic who replaced the clutch is now installing a flywheel shim and machining the flywheel as a fix. Does this seem normal? Is there another reason the cable would have snapped? First, we replaced the cable but every time we adjusted it, and turned car on to test, it went out of adjustment..
