Are you sure that is a real WEBER carb. When you say real cheap my radar went up. These phony weber carbs that have a sticker on them instead of the Weber logo in the casting are around, even on Ebay listed as Weber carbs. Just be sure your buying what you want and not what you think you want.
You can do a recurve on distributor advance, but this usually done with cam install.
Doesn't Oregon have a smog regulation law in effect? or is it the same as Washington State?
