Results 1 to 4 of 4
Thread: No low beam on my 91.
    WA
    The low beams are out on my son's 91, high beams work fine. Swapped out the control switch with a known good one but got same result. Wiring diagram shows a combination meter between the switch and the headlights but I can't locate it. Any help would be appreciated.
    1990 MM 4x4 3.0
    1991 MM 4x4 3.0 Diamonte
    WA
    Never mind, turned out to be faulty fuse connection. I always tell myself to stick with the simple stuff first, should have listened to that little voice!
    1990 MM 4x4 3.0
    Durham, NC
    Ive had the same trouble with my fuse connection, and a few others I know have too.
    hahaha you fixed it in 50 minutes..
