Engine swap
O.K. I'm considering doing an engine swap....I'm considering putting a 2.4 into my 1986 Ram 50 which currently has a G63B...but here is the difference from a "normal" swap...I want to drop in the 2.4 but use a carburetor instead of fuel injection....will the 2.4 engine and transmission just bolt in?....will the intake manifold from the G63B bolt up to the 2.4 cylinder head. any other information or suggestions to consider will be gratefully considered.
