Doctorates Degree
First up, ditch the 42 amp alternator. The extra load of audio gear on the charging system will actually kill engine performance (I have seen guys running big amps with a stock charging system and heard the alternator belt screaming from being under load
). I'd be going large - try and source something like an 85 amp alternator. Get a decent battery to back it up while you're at it. A strong charging system is your best friend and often gets overlooked when thinking about performing mods.
