Results 1 to 15 of 15
Thread: carb backfire.
    Kuna, ID
    4G63
    carb backfire.
    So as I was driving today my Ram decides to back fire my whole trip. So I belie it is running rich. Any ideas? Or does it just need a good carb adjustment? Thanks
    Did it just start to do it? I would look at timing then the jet valves and adjustment. then the cam timing in that order. One leads to another and when you got the cover off it's only a quick look to check things.
    Kuna, ID
    4G63
    Just started today.
    Somthing is getting off. Check timing and plugs, cap rotor. All the usual things. You will find it. I bet 5 bucks it's a jet valve going bad.
    Do a vacuum gage test and see if the needle is holding steady or whipping back and forth.
    Kuna, ID
    4G63
    If so. I have spares and a delete kit. 👍
    I wouldn't have commented on what the carby backfire issue could be caused by - none of the G63B engines that were installed in Australian sold vehicles had jet valve heads. I did get a cheap low km G62B from an importer that has the jet valve head. Good to know that this could be a symptom of a roasted jet valve.
    Kuna, ID
    4G63
    Should I delete the valves if this is the issue?
    Yes get rid of them.. We had a guy that had one going bad and it would blow vacuum lines off. Along with the backfire and low power.
    Kuna, ID
    4G63
    So I deleted the jet valves and it rid of the problem for about a day, then it began to backfire yet again. :/ I'm checking the timing with a light, when I can actually see the light and marks.
    Did you check the valves with a vacuum gage. The needle should hold nice and steady
    Kuna, ID
    4G63
    it was timing with the dizzy. runs great now!
    Wonder what caused it to pull so far out of timing...
    Kuna, ID
    4G63
    Indeed.
    So it was somthing simple after all.. Good for you.
    Kuna, ID
    4G63
    It's crazy how much a little thing can change so much on engines.
