Results 1 to 6 of 6
Thread: shifter issue
    Kuna, ID
    4G63
    shifter issue
    So when I put my transmission into gear, I have a lot of play. Feels like neutral. What could be causing this?
    Here's a place to start looking - http://www.mightyram50.net/vbulletin...hifter-bushing
    There isn't a lot that can go wrong with the shifter forks and rods. There are a couple of springs and retainers in the extension housing that 'could' break (but highly unlikely of) - that could make the shifter lever feel sloppy. The bolts holding in the top shifter plate can also come undone (lotsa fun when they pull out completely...)
    Las Vegas, NV
    1991 Mitsubishi Mighty Max
    That pretty much covers it ^^^
    I'd say either the bushing bit the dust, or the bolts came out. I ended up having to drill and tap my shifter bolts larger to get everything to actually stay.
    U.S.A.
    1986 Dodge Ram 50
    I'm leaning toward Merrills post, I just had a shifter issue and it was the nylon bushing at the end of the shifter in the transmission...my temporary fix is...I used a 1/2 inch copper cap, the type used to cap off a soldered copper water line, the OD is a perfect fit for the recess in the transmission and 3 wraps of electricians tape on the shifter ball that goes into the nylon bushing into the transmission....BTW...normally I would use the correct part but it was a Sunday and no parts stores had the part and I needed to go to the dealer who was closed.
    Las Vegas, NV
    Those nylon bushings are available in a ton of Mitsubishi cars. 1g/2g Eclipse, 3g/4G Mirage, Dodge Colt, Montero Sport (manual trans), the Mighty Max (of course), Eagle Talon, Eagle Summit, that silly looking FWD van thing, Conquest, Starion..... and a bunch more.
    I guarantee just about any junk yard would have one. If you are honest and try to pay, I bet they wouldn't even charge for it.
    Kuna, ID
    4G63
    I checked the bushing. It's still in tact. But I also looked at another 4wd and it has the same about of play?
