Results 1 to 9 of 9
Thread: led bulb replacement for stock bulbs
    Charles City, VA
    i just got my stock replacement led bulbs in today looks pretty good way! brighter then stock just waitn for it to get dark to see how bright they really are
    Bolivar, TN
    1992 Dodge Ram 50
    Exactly which bulbs did you replace, if ya don't mind me askin'?
    The 194 / 168 bulbs in the instrument cluster - the same ones I am about to change for the same reason.
    Tulsa, OK
    How many are in the Instrament cluster? I may do the same thing.
    Monticello, IN
    Quote Originally Posted by Sergio T View Post
    there was only two in mine. i went from the green rubber coated halogen to green smds. quite noticeably brighter. i replaced the brake lights as well and about to do the same with the license plate lights.
    Orange Park, FL
    Should be three total 194 bulbs actually, at least for the cluster w/o the tach. 2 for for the front lighting that are towards the bottom of the cluster, and one is in the center higher up on the backside that illuminates the odometer & tripometer. Just recently pulled my bulbs out and removed the green coating off the bulbs. Will also be getting some LED's pretty soon to replace them. For now, the white light is alot easier to deal with than the green.
    Yea there is 3 for the non-tach models and I believe 6 for the tach models(not exactly certain don't have mine anymore)
    Charles City, VA
    i replaced my brake light and tail light bulbs and my back up bulbs
    SC
    Also - the shift indicator on A/T trucks like mine takes a 74 bulb. I replaced my instrument cluster LED's with 5000K 194 LED's from V-leds.com and my shift indicator and also the cigarette outlet light.
    For what its worth, V-Leds has an AWESOME led dome light replacement. Pure, bright white and well worth it!
    RD
