Results 1 to 18 of 18
Thread: Is 1993 mighty max capable of towing a honda civic for a long trip?
    Atlanta,GA
    1993 Mitsubishi Mighty Max
    Hello guys,
    I have an upcoming non-stop 800-mile trip. I am thinking of using my 93 Mighty max to tow my 1991 Honda civic EF (with a tow dolly).. Is it a sound idea? I had the mighty for 2 years and it had made 30k miles for me with no issues. I replaced clutch when I first got it. It was leaking and burning oil slightly since the 1st day but not a big deal I kept adding oil to make sure no valve train noise. I did compression test, all good. I inspected timing belt, it is also good. I trust this little truck and usually make non-stop 150-mile trip with it. I am wondering if it can take this challenge......
    Las Vegas, NV
    1991 Mitsubishi Mighty Max
    I flat towed a Jaguar S-Type once.... the truck didn't like it, but it made it lol.
    There is a difference between a Honda and a Jag, but I don't really consider these to be trucks made for towing. I've been surprised by mine, but not sure I would tow that distance.
    I've towed many many cars on tow dolly's with mine, including Honda's. Should be no problem.
    I knew daredevils and I ain't got nothin' against them, ........it's just they're all dead.
    Oakland, CA
    They're not called Mighty Max for nothing.
    Keep an eye on the temp gauge.
    Mine pulls this really nice and it's just a 2.0L with a few extras.
    Just don't drag your clutch to much or it may start to smell. Get running starts on the hills and try not to overheat the engine. Curb weight on a 91 civic is about 2127 lbs. Try and remove all un-necessary items from the Honda as well as empty fuel in tank. Put a little extra air in all the tires, especially the towed vehicle so it will create less friction on a freeway drive. Clean the bugs and crap out of your radiator fins. When starting from a dead stop, take your time and screw everyone behind you if they are impatient. They will figure out how to get by on their own. You want to save the clutch from stress, so no hard downshifting when coming to a stop. Brakes are cheaper then clutches so hold the clutch pedal in when coming top a stop and use the brakes only. By the way, how is the timing belt. Rubber ones should be changed around 60k to 80k miles, sooner if the head is an interference style.
    sheffield, vt
    1978 Dodge D-50
    i think you'll be fine emergency stopping may be an issue
    Oakland, CA
    Yeah, the brakes might overheat if you're not careful. I would check the pads, drums and use fresh fluid. If you can, use a dolly with one of those automatic brakes.
    Maybe switch out the anti-freeze for water and Water Wetter since it's summer.
    Remember braking distance goes up exponentially with speed and weight! So give yourself extra, extra time and obey the speed limit.
    Make sure your brake lights and hazards work. Make the truck and trailer as bright and visible as possible. Whatever works so people can see you, as they're chatting on their cell phones and putting on makeup and eating Whoppers at 70 MPH.
    Atlanta,GA
    Thank you guys. I decide I'd rather drive the truck without towing the car... A lot of things can go wrong for a 800-mile trip.
    Before you nix the idea, if the tow is on flat land, it won't be that much of a problem. But it's up to you of course.
    Jacksonville, FL
    G54B-T
    Ive towed several cars on a dolly with my max. Maintain good distance in between cars around you and keep looking ahead for trouble as it will not stop as easily when hauling. I try to stay out of fifth gear unless at cruising speed.
    Atlanta GA
    For everyone who is towing with their Mighty Max or Ram50, are you using the bumper mounted tow ball, or do you have a receiver hitch type set up?
    Atlanta,GA
    I use bumper mounted hitch ball... I towed my Porsche 944 once with a tow dolly for about 30 miles... I do notice the bumper got stretched and bent...Anyone have better solution?
    Quote Originally Posted by leftfield6 View Post
    Receiver hitch.
    Georgia
    1984 Dodge D-50
    4G63
    I towed my 1984 Dodge D-50 with my 1980 Dodge D-50 from SC to Ga. with a tow dolly.
    Then took the engine out of the 80 and put it in the 84, and have been driving the 84 ever since.
    That was 1999.
    Atlanta GA
    Quote Originally Posted by Lon Moer View Post
    Receiver hitch.
    That's custom made, isn't it?
    I can't find a receiver hitch for the Ram50 from any of the usual online retailers.
    Oakland, CA
    I found possibly the last Draw Tite hitch for our trucks for sale in Canada, and I doubt I'll ever use it. Still brand new sitting in my garage.
    Atlanta GA
    PM sent!
    Wake Forest, NC
    I have not towed boats and the like as some of the other users have, but I have had so much crush n' run gravel in the bed on a twenty mile errand the rear tires looked flat. I couldn't believe the truck could carry that much weight. I didn't name it "Ol' Reliable" for nothing.
    Like it has been mentioned, your main concern should be braking distance. And you did not mention the terrain either. But a "flatland" tow should be fine if you use care- for example double you normal following distance. You will tax the brakes more than the chassis, guaranteed.
    Use common sense and be mindful of hills and brakes and you should be fine.
