Quote Originally Posted by turboskum View Post
Awesome. I'm going to order those today. Anything specific I should know about lifting the truck or issues I'm going to run into? I'm completely new to 4x4.
Here's the 3" body lift kit; JC Whitney, that should have some type of directions.
But the kit only shows the lift parts. You will also need to worry about longer shocks, brake hoses, fuel lines, ect. You'll probably have to cut some of the firewall to make clearance for the steering column shaft. You might also have to re-route the throttle cable. And a dozen other little details.
