heads are the same - the biggest difference is whether they are mechanical or hydraulic adjustors. If you do use the head, you need to use the truck cam unless you are adding a turbo to the motor. There are also differences in the truck cams whether they are mechanical or hydraulic adjustors, so chose wisely.
