Results 1 to 2 of 2
Thread: 2.6 Starion head
    Kuna, ID
    4G63
    2.6 Starion head
    has anyone done a starion head swap? What year is preffered?
    heads are the same - the biggest difference is whether they are mechanical or hydraulic adjustors. If you do use the head, you need to use the truck cam unless you are adding a turbo to the motor. There are also differences in the truck cams whether they are mechanical or hydraulic adjustors, so chose wisely.
