Freshman
1990 Mighty Max Keeps Cutting Out
I have a 1990 2.4L manual Fuel Injected Mighty Max. The problem is that while driving the truck when it gets to higher rpms it cuts out, but if you switch it to a higher gear it picks back up but will do the same thing and cut out at higher rpms. I was wondering if anyone had any idea as to what would be causing this problem.
