Results 1 to 2 of 2
Thread: Loose wire
    Fayetteville, GA
    1984 Mitsubishi Mighty Max
    4D55
    Loose wire
    I have a 1984 mighty max with 4d55. I have a wire connector on the left fender well that is not connected to anything. It is a white square connector with a white tether coming out of the end the tether has an loop connector on it to go to a bolt somewhere. Would someone please tell me where it should connect. I took the injection pump off to get it rebuilt and when I reinstalled it I found this wire and don't remember taking it off. Dang I hate when that happens. Does it connect to a ground or hot? I don't know.
    thanks for any help you can give me.
    Fayetteville, GA
    4D55
    Well I had no power when I turned the switch so I figured the wire need to be hooked somewhere hot I hooked it to the starter and everything appears to be working fine. I believe I have once again jumped the gun on needing help.
    thanks
